The RIDGID R86034 is a Lithium Ion impact driver manufactured by RIDGID in 2012.
Will not switch to impact mode
The drill will not switch to impact when drilling
Add a comment
1 Answer
Chosen Solution
Steve, If your drill is indeed switchable and not just a impact driver, if the hammer mode switch feels sloppy or to easy to switch, the switch has came out of position or broken a tab inside drill. If switch seems normal but you are not getting hammer mode the wing disc and gear could be seized, worn or broke. I will post a link, not your model but should be similar to show how the hammer function works and the common components. Good luck.
http://www.finehomebuilding.com/2010/02/...
Score 2
1 Comment:
If Steve is, in fact, referring to a Ridgid R86034, it is not switchable, it's just an impact driver. FYI for all
by
Add a comment
Add your answer
Steve Muller will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 30
All Time: 625
