Released in December 2011, identified by model number LT2016U. Repair requires screwdrivers and pry tools. Black / 10.1" Display / 1.6 GHz Intel Atom Processor
netbook FAN smells like DETERGENT
Hi there can I ask i just brought a 3g motherboard of gateway LT2016U at Ebay and i just wonder if this motherboard has a problem, just notice its smells like a detergent. on his cooler fan.
no problem with performance it runs smooths and stable fast. and operates in normal temp...
is this something wrong with this?
please help me thanks
Add a comment
1 Answer
I personally don't like the sound of a motherboard that smells like it's been cleaned with chemicals. It may however, just have sat for a long time in someone's home who uses a strong laundry detergent that lingers in the air. It would make sense that the dust particles in the fan particularly have a strong scent.
The only thing I would use on electronics is denatured alcohol, which evaporates quickly and shouldn't leave a smell. If the smell is more like an abrasive chemical cleaner and strong across the entire board, I personally would return it. Even small amounts of liquid can cause corrosion that manifests problems later down the road.
1 Comment:
Thanks for that info Patrick i am agree what you have said . well i will chat the seller of this motherboard.. so i can ask for refund. the reasons why i brought this because i want a built in 3G on my netbook and its hard to find a 3g motherboard here on ebay at cheap price.. well i will observe this and try to use it continuously to test if will cause a problem soon.
by
Add a comment
Add your answer
Nic Norman Tugaff will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 342
