Up to 20% off select tools
Guides and repair information for Logitech computer speakers and desk speakers.
Low volume on one speaker
I have Logitech X210 speakers and recently found the volume from left speaker is very low compared to right,...i have tried different speakers/headphones to subwoofers and it had same issue,.sometimes adjusting volume to a certain level balances audio o_O ...is there a prob with the aux outout port in subwoofer? any suggestions ?!
4 Comments
Hi, Just wondering if you have tried a different audio device from the one that you are using to prove whether the problem is in the speaker amp or the audio device supplying the speakers?
by Share
yes i have tried different devices and speakers to the subwoofer and same results ,i guess the aux output is loose in the subwoofer....any suggesttions to technically fix it?
by Share
Hi,
Try to clean jack connections, btw, have you tried to move the cable playing auidio, maybe its broken inside...
by Share
Just fixed it,
Go to device manager
Find your speaker ( should be bottom )
Disable it
Restart pc
Enable it
BOOM
by Share
Add a comment
Chosen Solution
Hi @Ayan Haldar,
The problem might not be in the sub woofer. Here is a link which details a similar but slightly different problem with a X210. There the problem turned out to be in the cable between the volume control and the sub woofer. Again with your problem you don't know yet whether it is low output on the left channel from the 'volume control' or from the output of the amp in the sub woofer.
This link has good pictures of the boards in both the sub woofer and the volume control and also explains what was done to find the problem as there is no wiring diagram available.
http://www.electronicspoint.com/threads/...
If you have little or no experience working on electronics initially it is quite OK, with the power unplugged and the unit is also disconnected from the PC, to carefully open the unit(s) and visually check the circuit boards and see if there is anything obviously wrong in either the sub woofer and the control unit, such as faulty capacitors (domed or exploded), heat stressed resistors and other components, dry solder joints etc. It would be unwise to probe the boards with the power connected as one slip could have catastrophic consequences and you would be worse of. There is also the very real danger of working in close proximity of lethal voltages, in the sub woofer at least.
You could take pictures of the boards, as was done in the link and post them here to see if anyone here can spot something that you may have missed. Adding images to an existing question
If this sounds all to daunting then I suggest that if you want to have the unit repaired that you take it to a reputable, professional electronics repair service and ask for a quote. If you do decide on this option at least that way they will be responsible if anything goes wrong during the fault diagnosis and repair of the unit.
Score 2
1 Comment:
@jayeff
Yup the problem is more likely to be with the vol. control panel as adjusting it to a certain level fixes it...I'd rather contact a pro for that..
thanks a lot for the help !
by Share
Add a comment
I had the same issue with my Logitech Z337.
I took off the volume control knob (just pull it out, don't be afraid to use a bit more force) and sprayed a little amount of WD-40 into the potentiometer. Then I rotated it a few times for the oil to settle and the issue is gone now!
Also, when I was turning the volume knob, the speakers were cracking, now this is fixed as well.
Add a comment
I had the same situation with a Logitech - z337. But just by turn it off and on was enough
Add a comment
Add your answer
Ayan Haldar will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 98
All Time: 28,764
