Up to 20% off select tools
Pentium M 1.6 GHz, 512 MB RAM, 40 GB HDD
SSD Hard Drive Kit
I have an old IBM ThinkPad T41 with a missing hard drive. I have an SSD drive, but I don't have anything to hold it in place in the hard drive slot. What items would I need to purchase ?
1 Comment
I don't know how crazy you want to get, but some good carpet tape will hold it :)
by Share
Add a comment
1 Answer
Chosen Solution
Hi,
You could purchase a laptop HDD caddy.
Most SSDs should fit into the caddy with the screwholes lining up.
Here is a link that shows how to remove the HDD from a T41 laptop. Just reverse the procedure.
http://www.laptopinventory.com/LaptopInv...
Here is a link, from just one supplier, that shows what a caddy costs and looks like. There are a lot more suppliers if this one doesn't appeal to you. Just search online for Thinkpad T41 HDD caddy.
http://www.tmart.com/Hard-Drive-Cover-Ca...
You may have to pack out the SSD a bit if it is thinner, to support it (even with the screwholes lining up) , so as to not place too much stress on the connectors. Any foam or rubber type material should be suitable.
Score 2
Add a comment
Add your answer
Brian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 1,242
