Model Number: M305D-S4829. Processor: AMD Turion™ X2 Dual-Core. Installed Memory: 4GB (PC6400 DDR2 800MHz SDRAM). Hard Drive: 250GB HDD. Display Size: 14.1" widescreen.
How do I undo an update
It worked fine until it updated. Now it is running so slowly I have waited over an hour for the control panel. How do I undo the update without the control panel? Can I boot in a safe mode? Can I boot from an external drive?
2 Comments
Hi, What OS is installed?
by
Thanks for everyone's help. I finally crashed the whole thing and I am waiting for a boot disc from Toshiba. It should have come with one but did not. Once it starts running again I will try these fixes.
John
by
Add a comment
1 Answer
Chosen Solution
Try to clean your system instead of an Downgrade using the following tools:
After each run, restart your computer :
1 - ComboFix ( <= Windows 8 ) Close your Anti-virus before you lunch it !
2 - ZHPCleaner
3 - AdwCleaner
It will work fine & very fast after that ! :)
Add a comment
Add your answer
J Robbins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 302
