A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
Really loose power cord
Hi everyone
Recently, my PS4's power cable has been falling out for no reason, even with the normal vibrations of the console. I'm pretty sure it used to be a snug fit but now even if I just touch it it falls out. Do you think it's just a faulty cable, or could the actual power port inside the console have moved? I tried slowly pushing the cable in but it won't go past a certain point and never fits securely.
6 Comments
Thanks, I've ordered a replacement cable so I'll give it a go :)
by
OK...hoepfully that fixes it. Be sure to post back here to let me know if it does.
by
Yeah, it was the cord, the new one fits securely. Thanks!
by
Great! Glad that fixed it!
by
I’m having the same problem rate now it wouldn’t turn on right if it’s a loose fit right plz say yes
by
Show 1 more comment
Add a comment
Chosen Solution
There's no way to know for sure without seeing it in person. You may be able to shine a flashlight in where the power plug goes and see if anything looks amiss. You also may want to just go buy a new power cable first. It's a lot cheaper and hopefully that would fix your problem. If that didn't fix it then you may need a new power supply (or yours could possibly be repaired).
Hope this helps.
Score 2
3 Comments:
I've had a PS4 since launch and have always had the same issue with an incredibly loose power cable, which would just casually drop out if I slightly move my ps4. I've only just realised you really need to push the cable in with some force and it will fit much more snug and will not just drop out. Bad cable design imo, most cables don't require that amount of force to connect properly so I didn't think this would.
by
What happens when i pull it up and it wont come on and i had it fix
by
Instead of buying a new cord just wrap a little electrical tape around the end of the cable
by
Add a comment
My power cable is the same and I'm getting my room done at the moment so I'm worried of moving it in case it doesn't turn back on
1 Comment:
Well i sent mines to be fix and now it my cord to it ugh
by
Add a comment
I had. Sent my ps4 to be fix and. Now its the power cord in the back of the ps4 this is crazy what to do someone need to tell me something
Add a comment
Add your answer
pandarock32 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 33
Past 30 Days: 107
All Time: 22,637
