Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
Why my ipad mini4 no sound?
how can i fix my ipad mini sounds?
Score 4
Add a comment
Chosen Solution
Make sure the device isn't muted. Check the rocker switch on the side and also press volume up. If that doesn't work, go into settings > sound and make sure everything is set right there.
Report back if you still have issues.
Score 2
6 Comments:
still no sounds
by
has it been dropped or had any water damage?
by
Still no sound. I'm typing this with my volume up and I can't hear the sound.
by
Still no sound..is it broke down
by
iPad mini 4 doesn't have a rocker switch.
by
Show 1 more comment
Add a comment
You can go to settings>General >reset>reset all settings. That should fix the no sound problem.
Score 1
Add a comment
piece of headphone is stuck in the port
Add a comment
Add your answer
scroll203 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 29
All Time: 19,221
