This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
I need to replace the glass
I have a LG v10 and I need to replace the glass
Score 4
1 Comment
The glass screen on this phone is repairable, but difficult. You can get it professionally repaired here: http://www.ebay.com/itm/LG-V10-Cracked-B...
by
Add a comment
Chosen Solution
Here is a link that should help. Tap or click on the blue link. Good luck.
https://m.youtube.com/watch?v=H5VDlpRFBK...
Score 2
1 Comment:
The glass is difficult to repair on this phone, but repairable. You can get it repaired here: http://www.ebay.com/itm/LG-V10-Cracked-B...
by
Add a comment
Most Helpful Answer
They sell just the glass online, but I would highly suggest you avoid that. The entire assembly is glued together and there are some very delicate components between the different layers. I was unable to replace just the glass and ended up destroying the whole LCD screen in the process. Your best bet is to buy the whole display digitizer touch screen assembly. They currently run about $150, but most of the videos online about replacing them include the entire assembly, including the one above.
Score 3
3 Comments:
I dropped my phone and the screen had spider web cracks. Then I just took off the outter screen. It was a pain in the butt but it still works as it did before. Im guessing the outter screen isnt the digitizer?
by
What did you do to remove the outer screen? Is your phone the V10?
by
I wish i knew that before i attempted it] not just the v10 but also on the LG stylo 2 plus.dead
by
Add a comment
Add your answer
Luis Milla will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 15
All Time: 6,631
