Repair guides, disassembly, and troubleshooting information for the third-generation Apple iPad with 4G, available with 16, 32, or 64 GB of storage. Released in March 2012. Identified by model numbers A1430 (GSM, AT&T) or A1403 (CDMA, Verizon). Repairs require the use of heat and careful prying.
iTunes error -1. Maybe Hardware defect?
Hi,
As anyone had seen the error -1 (unknow error)? Any suggestion for solution?
I had read, that is an hardware problem on Nand Flash, maybe right?
The iPad 3 (A1430) wont turn on after an update.
When i disassemble it, i had checked that the Main Board Flex Interconnector is broken.
I had resolder the terminals and buyed an new flex, but i have my doubts that this is the problem. I'm Wainting the Flex Arrive.
Sorry if some English errors :D
Best Regards
Paulo Silva
Score 1
2 Comments:
-1 is usually the baseband
by
Hi,
I will try to Reflow it and check if it works...
Many Thanks
by
Add a comment
1 Answer
was this resolved?? as im having the same issue
Add a comment
Add your answer
Paulo Silva will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 15
All Time: 716
