Support and repair guides for the 2002-2008 Mazda 6. The first generation of the Mazda 6, also known as the Mazda6 and the Mazda Atenza (in China and Japan).
Why wont it shift pass 3 gear
I have a 07 Mazda 6 and it wont shift pass 3 gear does anyone know what my problem is it has a 1.8 and a automatic transmission and my at light is on and when i switch it over to Manuel it does nothing its like it not even there
Score 4
Add a comment
Chosen Solution
Maurice,
Based on some quick googling, it seems like the Mazda 6s have several known transmission issues.
The quick and easy ones are the park switch, transmission mounts, and burning up transmission fluid. Unfortunately, it doesn't sound like any of those explain your problems.
Probably the most efficient fix would be to find a used transmission for a swap out.
Best of luck
Score 1
8 Comments:
Hey do you know where the shift solenoid is located in a 2006 mazda 6 with a 3.0L engine? please and thanks if you don't mind :)
by
I have a 2006 mazda 6 as well and am having issues. Sometimes my car stalls right after I start it and it is shifting late.
by
i have mazda 6 2009 2.5L it has a transmission problem gear dosen't shift after 3rd
by
I have a 2007 Mazda 6 same issue won't shift past 3rd and giving code that the shift solenoid is stuck open I changed fluid like I was recommended and unplugged the battery to reset the computer after doing so the car Will run like a dream all the way to 5 gear then when you come to a stop the light comes back on the at light and the engine light after lots of research I found out it's prolly the transmission control module that only Mazda or racing shops can get Mazda charges 600 for the part it's located under the dash under steering wheel if you take your car to Mazda they will tell you it's the transmission and charge you 3000 to fix it I found the part at a race shop had them order it and paid 160 I will install today and should fix the problem hope this helps someone
by
So did it fix the problem james ?
by
Show 3 more comments
Add a comment
Most Helpful Answer
Maurice, Could be a faulty shift solenoid. Have vehicle scanned for trouble codes by a good Tech., diagnosed and estimate repair.
Score 2
1 Comment:
by
Add a comment
Hello. I have a 2008 Mazda 6. It says solenoid 2 when put on computer. It won't shift past 3rd. So I got a new 2nd solenoid changed it and didn't fix it, it still doing same thing. I bought that box that has the 6 solenoids in it and had it put in and it did shift to 4 and 5 two times and that's it. Was stuck right back in 3rd gear. Ugh. So I then got a modular and had put on , still no change…. I took to a dealership and had put on computer and cleared transmission. And..still no change, its still stuck in 3rd gear!! Ugh… Can someone plz plz help me out here?? I'm ready to pull my hair out with this car. Really can't afford a transmission for it. Thanks. Christy.
Score 2
3 Comments:
Its the wiring going from the solenoid to the tcm....I believe kt to be an orange wire
by
Some time, solenoid do go bad, but the worst thing to check, is the condition of the wire connectors. Bad bad connection corrosion or break in The wire from the sensors on the transmission itself. The wiggle the wire test is usually the first start.
by
where is the solenoid?
by
Add a comment
On the Mazda 3, 5, and 6, if it is having the issue of not getting out of 3rd it will most likely read a bad solenoid. Even if you replace all of them on the transmission, you still have the chance it will not fix the problem. Instead of replacing the transmission, switch out the TCM, (transmission control module) and see if that doesn't fix your problem. Should shift as smooth a silk. Also another thing to check with that problem would be the speed control sensor.
Score 1
1 Comment:
I just purchased a 2007 mazda 3s automatic/manual. It won't go past 50mph. Took.to mechanic replaced the vehicle transmission speed sensor and gave put 3rd and 4th gear codes. Shop said new transmission. :(
I just picked up. Any advice? Anything I can.check myself or anything??
by
Add a comment
My 2006 Mazda 6 had about the same issue first noticed my battery light coming on then the next time I drove it it would go from 1st to 3rd and stick there didnt mater if it was in manual mode or normal would not change out of 3rd gear, I disconnected the battery and cleaned the battery posts put it back together and been good ever since guess we got lucky with it hope this helps someone
Score 1
1 Comment:
Doug, I tried this first and haven't had another problem (like this) since. 2006 Mazda 3.
by
Add a comment
Mine had a bad part in the gear shifter its self there like little buttons when. You put it in gear that the shifter hits it it bad then it does not realize it's been put in that
Add a comment
https://www.youtube.com/watch?v=E1i1giTP...
1 Comment:
Today I have checked it and worked.
by
Add a comment
Add your answer
Maurice will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 107
All Time: 28,479
