Up to 20% off select tools
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
No Sound...how to repair?
I have a Nintendo 2ds and the sound doesn't work....is there a way to repair?
Score 3
1 Comment
Me too some times there's loads high pitched noises
by Share
Add a comment
1 Answer
Chosen Solution
Tyffani, You are not the only one with the sound on your Nintendo 2ds not working. It may be the ribbon cable connection, internal of the device or if your volume control feels very free, the switch may not be connected to the internal mechanism. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button.
http://en-americas-support.nintendo.com/...
https://www.youtube.com/watch?v=4S_Hc9vN...
https://www.youtube.com/watch?v=fwXzZw8I...
Score 3
1 Comment:
@lucsen, Lucsen, check out the advice and links above to trouble shoot your issue.
by Share
Add a comment
Add your answer
Tyffani Sutherland will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 37
All Time: 7,659
