Sony Xperia Z3 Compact released in Sep. 2014.
wifi problem after lcd and back cover replacement
hello, i'm Dan, i have a problem with my z3 compact's wifi. I replaced the lcd and the back cover, and the wifi don't work good... The signal at 2,4GHz is so bad and at 0 mb in download, with the 5GHz is a bit better but not enought. I don't know where is the wifi antenna, and if i could touched it or broked it when i moved the motherboard or others.
Score 2
Add a comment
1 Answer
Most Helpful Answer
Check connetor on mainboard and plastic main frame. Wi-Fi antena is in a frame. Check screws and spring connector on mainboard (it goes to frame). Maybe you can broke it or distort it.
Score 1
Add a comment
Add your answer
dan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 1,077
