Gaming laptop released in 2014 with an Nvidia 860M graphics card and a 15.6" display. Updated in 2015 with 960M graphics.
Can I replace my screen with IPS one?
I bought my laptop with TN matrix display and that everybody know there is very bad colors and angel of view. What type of screen I need to get and replace ?
Score 1
Add a comment
It's really hard to take screen with different display , neither TN , IPS , or anything like that.
You can do it, but it's really hard as i said because you will have to test a lot of monitors to find the compatible one, even though you will have the right code.This doesn't mean that it will be compatible with your laptop.
Add a comment
Yes you can replace it. There are a lot of tutorial available online. You can find for B156HAN01.2 replacement IPS screen and replace it with your current TN Panel
1 Comment:
Thats an AHVA panel not IPS
by
Add a comment
As long as the pinout and connector type on the replacement panel matches the old one (a lot of Haswell-present laptops use iDP instead of LVDS now), it’s doable. However, the Y series is harder then most laptops because Lenovo decided to fuse the screen to the glass with UV LOCA glue.
On the Y700, the screen is fused to the glass assembly across the board, but the Y50 *may* be salvageable. However, the problem is if you have a touch screen assembly, it shares the same fused design as the Y700. You’re good if it’s non-touch, but if it’s touch that may be a problem. It does sound like it’s non-touch since you mention it isn’t IPS, so that’s going to work in your favor.
Add a comment
Add your answer
denizramadanov will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 18
All Time: 998
