The Toshiba Satellite C655D-S5084 is a mid-cost laptop that is a part of the Toshiba Satellite C650 series. The C655D-S5084 is a customized version of the base model.
Turns on and off when booting
I scored a Laptop for nothing but it has a problem where it will not boot at all.
I am told at some stage someone replaced the RAM but and instantly stopped working.
When you try to turn it on it has power and attempts to boot but the screen stays black and after about 10 seconds it turns off again?
I have reinstalled original 4GB of RAM and removed the HDD to see if it would take me to the BIOS, but nothing seems to work.
Any suggestions would be helpful thanks.
Add a comment
1 Answer
Is there multiple slots to install the Memory? Could be that the slot you are using is bad. That or the memory isn't currently seated all the way in the slot.
Add a comment
Add your answer
Harley Greaves will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 276
