Also known as NX.MH1AA.011. This 15.6" LED touch screen laptop was released in June 2014.
Laptop Key (W) is not working properly
Hello.
I'm using Acer Aspire E1-510 laptop and my "W" key started "blocking and freezing" 2 days ago. I don't know why is that happeing but i thought it was because of the dust,so i vacuumed and it didnt help. I also removed the key and tried a "deep" dust clean,but it didn't work...
Sometimes it works normally but sometimes i have to push it about 20 times to write a single "W".
Sorry for my bad English :)
Cheers!
Add a comment
1 Answer
Chosen Solution
Usually this is because of debris or dust on the connector for the keyboard. My laptop had this problem.
I took the laptop apart until I could get to the keyboard connector. I removed the keyboard and cleaned the connector by taking an eraser and "erasing" all the dust off. The pins were a lot more shiny and the keyboard worked perfectly after that. I hope this helps.
It could also be helpful if you searched "Acer Aspire E1-510 keyboard replacement" so you can see how to properly remove it.
-Jono
Score 1
Add a comment
Add your answer
Dino Covic will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 695
