Repair and disassembly guides for Kenmore Microwaves.
Why are some buttons not working
Some of my buttons are not working - like the numeric 5 button, the exhaust fan, and the STOP/Clear button
Score 2
3 Comments
Hi,
I have sanyo Microwave Oven em-p540w,
yesterday touchpad wasn't responding, so i unplug 15 minute per your suggestion,
and plug back up, works like charm...
and 2 hours later again touchpad wasn't responding, so unplug and replug...
it's work again only for a while and take a nap...
Is this ready to trash?
by
My micowave start button not working model sonakshi send me how to repair it
by
Why is my microwave #2 button say #3 when I press as wrong number? Also when I press auto reheat button it automatically go to potato mode instead of castrolle. Since #2 button said #3, I cannot set time as pm anymore. Just started this issues a month ago. I unplugged and plugged it back on and still have issues. Any suggestions? Please.
by
Add a comment
Chosen Solution
Unplug it for 15 minutes to allow it to reset. If the problem persists please give us your model number and I'll look at it further.
Score 4
6 Comments:
I have tried that, but it did not work. The Model Number is 401.80084700
by
Cause 1
Touchpad and Control Panel
To determine if the touchpad and control panel are defective, try pressing each of the buttons on the control panel. If some of the buttons respond correctly while others don’t, replace the touchpad and control panel.
Cause 2
Touchpad
To determine if the touchpad is defective, try pressing each of the buttons on the control panel. If some of the buttons respond correctly while others don’t, replace the touchpad.
Cause 3
User Control and Display Board
To determine if the control and display board is defective, try pressing each of the buttons on the control panel. If none of the buttons are responding correctly, replace the user control and display board.
Here's how to remove the panel, finding the part may be harder:
https://www.youtube.com/watch?v=YsBQYHdy...
by
i have a gc but it works except the number buttons
by
Pearlita, see the 3 causes right above your question.
by
Samsung mw73ad-b/xtl . Only clock button and its minute & hour button respond. The minutes and hour button serve the dual purpose of setting time for 1 minute or 10 minutes. They do not respond except while setting time. Rest of the buttons are not responding
by
Show 1 more comment
Add a comment
I’ve replaced my control panel and touch pad and still have buttons that don’t respond the main one being the start button. Is there anything else that can control this?
Add a comment
It may not be necessary to replace the touchpad and the control panel. You can take a blow dryer move it back-and-forth over the pads that don’t work, and keep pressing the pad up and down. they may come unstuck. This has worked for mine on several occasions. What happens is when you’re cooking the grease Will cause them to stick over time. Give it a try before you throw everything away.
Add a comment
Add your answer
Alex Pechenik will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 85
All Time: 50,278
