The third iteration of Lenovo's Yoga line of notebooks, similar in design and hardware to its predecessors. Designated by model number 80HE000DUS.
Plastic strip on bottom of display
I have replaced the display (not for the faint of heart) and everything is working beautifully. However, I can not get the plastic strip to stick back on to cover the screws at the bottom. Do I need to buy a heat gun to melt the glue? I want it to look perfect.
Add a comment
i used plastic super glue to fix mine about 2 months ago and its holding up beautifully. just used four small drops along the strip and held each one for about 45 seconds.
Add a comment
Try some double sided tape and blow dryer. Apply the tape to the rear of the plastic, and heat carefully with the blow dryer to form a tacky surface more than what the tape is now. This will also insure a tight bond of the tape to the plastic. CAUTION! DO NOT HEAT MORE THAN NECESSARY!
Add a comment
Add your answer
karengail will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 525
