Up to 20% off select tools
Amana Refrigerators are manufactured by Whirlpool Corp group, in Amana Iowa.
Freezer not circulating cold air
I have a Amana SRD25VPE and it all of a sudden stopped cooling itself. The bottom part of the freezer will maintain some frozen items, but the upper half of the freezer will not. The right side on the other hand will not receive anything.
At first I thought it was the frozen coils, so I defrosted them and noticed the Evaporator fan wasn't running. I thought this was the issue, so I replaced the Evaporator Fan Motor. After installing the fan, it started to spin, so I closed everything off and thought it was fixed. But still nothing is getting circulated.
After that, I tried defrosting the whole freezer overnight to see if ice was built up in the vents. The fan kicked on after turning it on, some air seemed to be coming out. But after checking it out after an hour, the fan stopped and air doesn't seem to be circulating still.
Any ideas?
Add a comment
1 Answer
Chosen Solution
Temperature Control Thermostat
The temperature control thermostat directs voltage to the compressor, evaporator fan motor, and condenser fan motor (if applicable). If the temperature control thermostat is not working properly, it may prevent the refrigerant system from running. To determine if the thermostat is defective, rotate the thermostat from the lowest setting to the highest setting and listen for a click. If the thermostat clicks, it is not likely defective. If the thermostat does not click, use a multimeter to test the thermostat for continuity. If the temperature control thermostat does not have continuity at any setting, replace it.
Temperature Control Thermostat - Mfg Part # R0161092
Regulates internal refrigerator temperature for optimal freshness. Image
Product
Whirlpool Refrigerator Temperature Control - R0161092
$114.99
Score 3
Add a comment
Add your answer
Dan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 3,191
