Up to 20% off select tools
The Samsung Galaxy S4 Active is a rugged version of the Galaxy S4. Currently, it is only on AT&T's 4G LTE network.
Getting around screen burn-in
My Galaxy S4 has a burn-in problem. It's good for an hour or so, but then videos become un-watchable, and I have to not use it for a while before it goes back to normal. But every now and then, when I re-boot, the colors appear duller, but much better than when it's all burned-in. This goes away after about ten minutes. Is there a way to force it to stay that way? Some kind of setting or app I can use?
Score 3
1 Comment:
I haven't heard of this issue before, but have you ever considered replacing the LCD? Your phone is older now, and I have the same model. I just recently had to repair mine. You can find a cheap LCD on ebay, but never get one that was refurbished. You may also want to get an S4 for donor parts, which is also available on ebay. Hope this helps!
by Share
Add a comment
1 Answer
I'd replace the lcd, pretty simple process, follow my teardown and you shouldn't have any issues Disassembling Samsung Galaxy S4 Active
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 27
All Time: 1,366
