The Bose SoundLink Mini II is a Wireless Bluetooth Speaker that delivers high quality audio from a compact design. The device weighs approximately 1.5 pounds and has a Bluetooth range advertised up to 30 feet. The device was released after June 26, 2015 and is Identified by model number 725192-1110.
How to attach rubber pads at the bottom?
I took out the rubber pads at the bottom of the speakers to try out the charging cradle and I'm finding attaching it back hard.
Score 1
Add a comment
1 Answer
Struggling with this as well - the rubber tongue won't go in... Any ideas?
2 Comments:
After a long struggle I finally just cut the tongue off. I then put the silicone foot pad back on the speaker and after months of using and moving it the pad hasn't come off. Get a pair of scissors, take a deep breath, and cut that thing off!
by
Thanks for re-assuring!
Eventually after a similar struggle that's what I already did :) Looking at other instructions, it seems that one needs to remove the back grill and then use tweezers to catch the edge of the tongue to pull it in. Since the grill is held by a sticky tape, I think it will be quite challenging to fit it back in a way that it will look like new - in fact, none of the instructions show how the device looks after assembling.
So I well decided that the tongue is not that functional and indeed the rubber pad is held well with it's edge grooves.
by
Add a comment
Add your answer
Francisco Santiago will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 55
All Time: 2,906
