Controller Port 1 doesent work
Hey Everyone,
I got a Dreamcast from Ebay, but the Controllerport A/1 doesent work. All the other, B/C/D works perfectly.
I hope you can help me
Hey Everyone,
This guide would be the easiest, if you don't want to solder it
Sega Dreamcast Controller Port Replacement
This guide would use a little more work, but you could individually change out one controller port
Also found this on eBay
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 1,895
3 Comments
Do you know how to solder? If you don't, your best bet will be to purchase a replacement controller board off ebay and simply swap out the part.
by Ben Eccles Share
yes i can solder, but why?
i read a lot of the problem on the internet, but that is always all controller prots, not only one. so i think the problme withe the fuse coulnd't be
by thunderblrd Share
The reason I ask is that controller port board on the Dreamcast is among one of the more friendly parts for soldering, since all the components are through-hole. I would do a continuity test on the fuse, just to rule it out as a problem.
by Ben Eccles Share
