Up to 20% off select tools
How do I replace charging port?
How do I fix this problem.
Add a comment
hello,
i do not know the model that well, but normaly it is soldered to the mainboard.
If it is soldered to the mainboard : you have to unsolder the old one and replace it with an other charging port , solder it properly .
there are many guides to solder ports on ifixit
good luck,
Kind regards,
Kevin
Add a comment
This answer was originally to another question.
see explanation in other post you have.
You will have to solder. (most likely)
Kevin
Add a comment
Add your answer
chris will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 145
