Nikon D600 24.3 MP CMOS FX-Format Digital SLR Camera
How do I open this ZIF? Connector?
Hi,
This is the underside of top of my D600 that I dropped. To mend the top display I had to remove this board and do some soldering.
I pulled out the ribbon that goes into the white connector at the bottom of the board as you view it - see attached photos.
I pushed back the ribbon, although it did no go completely in. After re-assembling the camera I found the wheel under the forefinger inperative.
How do I unlock this, I have so far not tried too hard as I must not break it!
hope someone can help,
John
Score 1
Add a comment
every zif connectors have a plastic lock on it, just unlock with a small flat screw driver and pull out the ribbon cable carefully, when reconnecting extreme care should be taken.
Add a comment
The black part of the connector is the part that flips up to release the ribbon cable. Still be gentle with it.
Add a comment
Add your answer
John Bishop will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 35
All Time: 909
