The first generation Mazda MX-5, or Miata.
transmission is stuck in reverse
who do get a maual trmission out of reverse?
1 Comment
Thanks Ray for the effort!!
by
Add a comment
1 Answer
Chosen Solution
Hi
Adjust the clutch wire..leading to the gear box
or push the clutch arm on the gearbox..while someone in the car pushes on the clutch peddle then wiggle the gear stick free!
Happy driving
Ray
1 Comment:
MY Mechanic friend found on another blog that this is a common problem for some early years; even after a recall repair. He said remove reverse light and use a small flat screw driver to move actuator....With a $50 tow and $25 repair, I guess we all may have learned a leason.
by
Add a comment
Add your answer
RICKY WEEKS will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 19
All Time: 2,082
