The Skullcandy Air Raid is a wireless portable Bluetooth speaker released November 15th, 2013 which streams music from any Bluetooth-enabled device.
Where to buy battery
where can you buy a replacement battery for my air raid skull candy speaker
Score 1
Add a comment
Would you be able to post an image of the old battery? Often times custom battery packs are obscure and cannot be easily obtained, but depending on the cells I may be able to see if I can find you a source to purchase new battery cells to repair/rebuild the old battery yourself.
Add a comment
It seems like a 3cell lipo, about 2000mAh you should get something suitable in rc.model shop....
Add a comment
Original battery - it is actually 2 x 1000mAh batteries so I replaced with a single 2000 mAh battery. The limiting factor is the compartment size which is about 54mm x 34mm by about 10mm thick. Note this has a third wire for thermal protection. Btw the number 553450 refers to the size (I guess 55mm x 34mm x 5 mm but since there are 2 batteries the last 5 is actually 10mm)
Replacement: the replacement number refers to 10mm x 34mm x 50mm so a bit shorter which is fine.
Wires were too short and connection was too small so had to solder on old wires with connection: (CAUTION: Lithium Ion batteries are extremely flammable and dangerous so use caution or find a better replacement)
Add a comment
Add your answer
mel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,221
