Up to 20% off select tools
This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
Phone will not charge
My phone will not charge. All it does when I plug charger in. Screen stays at 0% (screen shows this) but that's it.. will not charge
Score 2
Add a comment
Chosen Solution
Try replacing the battery like the other comment said. At my phone shop that would be one of the first things we would try. Also try a different charger that might be the issue, the charger you are currently using may not be giving out enough power to charge the battery.
Score 4
Add a comment
First step would be to replace the battery.
Score 1
Add a comment
Did that, replaced the grey battery with an aftermarket one off Ebay. It's been 8 months. Now the phone won't charge again. Did the USB cleaning. Changed chargers. Still it gets hot when charging. Won't charge phone says “slow charge” not sure what to do next
Add a comment
I done everything change battery change charger.its says 0 charging charge before using I put on charging 5 hour same problem showing me again
Add a comment
Add your answer
tamrobbins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 4,002
