The Panasonic TX-32LX70 is a 32-inch LCD (liquid-crystal display) high-definition television from Panasonic.
How To Repair My Television
Plz suggest me how to repair my Tv.
Last 2 dy my Tv screen cut image .
Tv up side like negative screen & down side Normal so plzz
what's problem...
Update (06/12/2016)
See up side crop picture
2 Comments
post your question in normal english and a little bit more details. And a good picture would help to...
by
What's Problem My Tv.
Plz Tell Me Details...
I hve open My Television And Clean Dust Also.
Bt No Idea What Can I.
So Plzz Explain Me..
This Problem Faced Last Two Weeks .
Power Shut From Electricity .When
Power Come That Time To Till Date This Problem Faced..
I Don't Understand What's Problem on Television..
by
Add a comment
1 Answer
Chosen Solution
@mayur unlikely that this would be caused by a bad LCD or a bad driver logic. I would suggest that you start with your settings first. Make sure that you have things like "mirrored" etc. not accidentally turned on. If your menu has a factory reset, try that.
If you are 100% sure that your settings are right and that a reset did not resolve this, you'll have to open up your TV and take a look at the boards. Check for obvious damage and post images of those boards with your question.
Score 3
3 Comments:
by
@mayur Have you done a complete reset yet? Go into your TV's setup menu
by
Which side show reset menu
by
Add a comment
Add your answer
mayur will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 25
All Time: 419
