Up to 20% off select tools
The Airport Time Capsule is a wireless router and network-attached storage (NAS) device manufactured by Apple. Model A1409 is the fourth generation revision of the Time Capsule released in June 2011.
My reset button is broken...
A1409.... tried to reset... guess I pushed the reset button to hard and now the plastic interior reset button seems to be gone.... what can I do?
Add a comment
1 Answer
If you simply jammed the button in the case, you should still be able to get to it by dissembling your device with guides from ifixit and then unjamming the button. If the switch itself is damaged you will have to short out the pins of the switch beneath the button with a wire.
Add a comment
Add your answer
Scott Ross will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 1,040
