Support for percolators manufactured by Farberware.
My percolator is not heating
My percolator does not heat at all. When I connect it, the water remains cool. The base becomes very hot after some time, but does not heat the water. Does anyone know what is wrong with it, and how to fix it? I have a Farberware millenium percolator, model fcp240.
Score 2
1 Comment
I have FCP 240-A model that stopped heating. How do you take it apart? The bottom screw comes off easily but the there seems to be a bolt inside the pot that needs to come off. I can get leverage with a wrench. Suggestions?
by
Add a comment
Most Helpful Answer
@nadeshko could be a thermostat as well as a heating element issue. time to take it apart and inspect. Take a look at this video for an idea of what to look for. If in doubt take plenty of pictures and post those with your question. Use this guide for that.
Score 1
Add a comment
If your Farberware percolator is not heating up, there may be an issue with the heating element or thermostat. Check to make sure they are clean and free of any mineral deposits. If they are damaged, they may need to be replaced.
Another possible issue is the power cord. Make sure it is securely plugged in and that the outlet is working. If the power cord is damaged, it may need to be replaced.
For more information kitchenzap.com
Add a comment
My percolator does not connect to electricity
1 Comment:
@patrobus not enough information here give us more details. What do you mean it does not connect to electricity? Give us more of a description
by
Add a comment
Add your answer
Andrea Garcia will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 43
All Time: 5,510
