MacBook Air SMC problem
Hi all,
I have a problem with my macbook air 6,2.
The first issue was the computer did't turned on.
The SMC reset and regular things did't helped.
I took down the bottom case, and plugged out the battery cable. After this when I plugged in the charger, the computer is turned on immediately.
I took back the case, and restarted the computer, the computer was dead as before.
I ran a hardware diagnostic test and got the PPT001 (battery), PFM001 (SMC) and NDC001 (webcam - this one is weird because I can use the camera).
So right now I can turn on the computer without the bottom case, but the fans are running high etc.
The power adapter led is not lighting, and when I push the shift + ctrl + alt the computer is turned off immediately.
Anyone have an idea what can I do with this SMC issue?
3 Comments
Hi,
I have exactly same issue with my Macbook Air 13" 2014.
How do you repair it?
by Jakub Zelenka Share
First issue was fixed without any intervention. I just waited few days..
The secound issue was the SSD, so I just replaced it. Maybe the first issue was an SSD issue as well.
by wntsmk Share
@wntsmk I have the exactly same issue with macbook pro mid 2012 ....what I have to do please help me
by Prince Gupta Share
