The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
2DS Black Screen while power on
So a few days ago, I left my 2DS on the sleep mode for a while and I might or might not drop it accidentally. I don't remember and found out later that when i push the power button to turn it on, the blue led lights and the screen is black,
not black like it was turn off but black we definitely see that it is turn on but won't show anything. (backlight working probably?)
I tried to hold the power 10 seconds and wait but the only image i can see is when I push the power button when it's on and it asks you if you are sure if you want to turn it off. From there, and from there only, I can push the home button and it shows the white screen telling you you're going to the home screen. but it is stuck there and won't go to the actual home screen.
I want to know what exactly is the problem here and if you know how to fix it i would be grateful.
thank you
Score 1
3 Comments
Mine is staying black period! I cant do anything at all! I cant take it apart because Im not techy. I will tell the story and tell me if you can fix it in any way! I got Kool-Aid inside of it! I can turn it on but it is black and it makes sounds like I am choosing a game! I need help D:
by
Unless there are other things not responding properly, it just sounds like the LCD screen needs to be replaced. This can be replaced fairly easily .
by
I have a 2ds xl which dosent have a sleep mode switch but just black screen when turned on any ideas?
by
Add a comment
Most Helpful Answer
I had this the other day turns out when you accidently knock the ds when in sleep mode the sleep button dislodges from the switch just flip the button back and forth till it connects back with the switch might take a few speedy flips to jolt it back in.
Score 3
5 Comments:
"I had this the other day turns out when you accidently knock the ds when in sleep mode the sleep button dislodges from the switch just flip the button back and forth till it connects back with the switch might take a few speedy flips to jolt it back in."
The issue you are describing sounds like a 2ds stuck in sleep mode, which is a bit different from what the poster described, as on sleep mode, the 2ds won't have the backlight on, nor will it show the home screen option.
by
thank you so much
by
bro saved my childhood console tysmmmmm
by
My console is just a normal non modded 2ds I found in a drawer I've had since I was a little kid it definitely had some drops and the screen is black I tried flipping the sleep mode and it didn't work it charges and it can die idk what to do I'm lost
by
Mine is doing this as well. However, on boot up, it goes to just a backlit screen nothing more. When I turn it on to sleep mode, the screen turns off. Turn Sleep mode back off, backlit shows but no picture, no sound. Will go into safe mode and update and can delete home menu but nothing. When holding power button the power menu comes on screen, I just click the home button, and it stays on a white froze Home Screen that says home on bottom screen while top screen is just white. Any help, would be appreciated. Has a new screen cause it was popping but be screen fixed that popping sound.
by
Add a comment
I have a similar issue, where I turn on my 2DS and the screens turn on, but stay black. But your issue sounds like hardware failure, maybe the motherboard was damaged in the possible fall. You can get replacement motherboards for around $20 or more, and there are a great deal of tutorials online on how to replace them. Good luck to you!
Score 2
1 Comment:
Or you could remove the WiFi chip and put it back in
by
Add a comment
I was having this problem too but I was messing with the power and home buttons on my 2ds(non-flippable) and I got to the return to home/power off screen then went to home normally.
Add a comment
dind work pls help
Add a comment
Add your answer
MaryEve will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 55
Past 30 Days: 244
All Time: 31,140
