Up to 20% off select tools
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
Graphics Issue
I am having a Graphics issue with an iBook G3, the graphics keeps causing the Screen to either go blank or go White with 2 Blue Strips down it, Please reply with a fix and possible a pic for demonstration
Score 1
Add a comment
Most Helpful Answer
unfortunately you are probably experiencing a common issue with this series - the graphics processor either fails or its solder joints to the logic board become loose.
some have had success using non-conductive material (folder paper square, etc) to create a shim between the chip and the case, causing force and pressure to hold the chip stable. others have been able to get the chip solder reflowed.
see these existing answers:
Why does my iBook randomly freeze?
Display Screen stays black, but computer still works good
Score 1
Add a comment
You could check this out.
http://cgi.ebay.com/iBook-G3-Logic-Board...
Add a comment
Thanks everyone
Add a comment
Add your answer
Darth Seleyus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,780
