Up to 20% off select tools
The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
MacBook Pro LCD Repair
Is this also recommended for use on a Macbook Pro (Mid-2009 Unibody)?
Add a comment
1 Answer
Chosen Solution
I use that. the heat gun and the picks to remove the glass.
iFixit Opening Picks (Set of 6)
Heat Gun
iOpener
Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C). Image
Product
Heat Gun
$29.99
Thin prying tool for opening electronic devices. Opening picks are essential to open any iPad, tablet, or smartphone sealed with adhesive. Image
Product
$4.95
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries. Image
Product
iOpener
$24.95
Score 3
Add a comment
Add your answer
takeogarcia will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 35
All Time: 447
