The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
Where is the fuel filter?
location of fuel filter?
Score 2
2 Comments
gas or diesel ?
by
Thanks for the help.
by
Add a comment
1 Answer
Chosen Solution
Depending on the year of the truck if its gas or diesel there are several locations . On the diesel its located next to the master brake cylinder. On older gas models its mounted on top of the fuel tank next to the sender unit on some of the newer models its mounted to the frame rail next to the fuel tank . Easiest way to find it is to start at the fuel tank sender unit and follow the fuel lines to the engine. you'll find it in there somewhere. If your not seeing it odds are its one of the ones mounted on top of the fuel tank. Hope this helps
Score 5
Add a comment
Add your answer
Terry will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 28,980
