Up to 20% off select tools
A Nokia E-series smartphone with a physical QWERTY keyboard and Optical Navi Key. Successor to the E71. Released in 2009.
USB charging not working
WHen I connect using micro USB cable to the charger, its not getting charged. I can only charge the phone using the charging port at the bottom. Also when connecting phone to the USB its not even detecting. How can I fix or repair that.
Add a comment
Most Helpful Answer
Hi Sandeep,
Try this:
Remove the battery in order to avoid short circuits during procedure.
Take a needle and pick out all dust and dirt that is in the USB socket of your device. Quite a bit will be there.
After cleaning, reinstall the battery.
I hope this will help
Score 1
Add a comment
how to fix not charging idk too ngl this is so annoying proplem
Add a comment
Add your answer
sandeepthomas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 1,772
