The Dremel 8220 variable-speed cordless rotary tool offers the highest performance of all Dremel cordless rotary tools. Released Date: June 22, 2012
Why is my Dremel overheating?
So I've been using this device for about 3 hours and within that time I needed to charge the battery. When i did that I used it again right after and while I was using it, the device seemed very hot, the battery specifically. What's wrong with my device?
Score 1
1 Comment
My flex shaft is getting hot, not the actual Dremel. The flex spring is very hot after about 10 minutes of operation.
by
Add a comment
Chosen Solution
1. You used the device for a long period of time and the battery really got hot, just turn it off and use it again after 20-30 min.
2. Your fan that cools the device might be broken. The fan is what cools the device and stops it from overheating. If broken just remove the fan and add a new one in.
Add a comment
Most Helpful Answer
I live in an Apartment- I found out on mine, It was my problem… I was runing it at to low of Speed. To keep the sound down….. End of my motor.
Score 1
Add a comment
They use a TO-220 MOSFET inside with a terribly small heatsink and a small glueless mating surface between the MOSFET and the heatsink with a loose rivet. The MOSFET can get too hot and blow (small puff of smoke, sparks…etc.) I just ran into this myself. I’m going to have to desolder the MOSFET(s, there is a second one beside the TO-220) and put them on a better heatsink, properly mated as well. …Conveniently a month after the warranty expires.
*Edit* For anyone needing to replace the electronic assembly inside, the part number is 2610005464.
Add a comment
Add your answer
Meeley Bien Aime will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 58
All Time: 8,932
