Up to 20% off select tools
Flashing Lights on Control Panel
Last night, I went to start my dishwasher. I pressed the Start button before noticing that I was on "Pots and Pans" instead of "Normal". I immediately pressed the "Cancel" button in order to change the cycle. I heard the drain cycle start and finish, then I saw the "Normal" button flashing. I could not select any other cycle, and got no reaction when pressing "Start". I pressed the "Cancel" button again, but it just started flashing as well as the "Normal" button. At this point, I flipped the circuit breaker off, counted to 10, and flipped it back on. This made the "Cancel" button stop flashing, but the "Normal" button kept flashing. I then checked the interior to make sure that the overfill cover moved freely, that the sprayers could all turn freely, and that the filters were clear. No change. I tried the reset procedures found elsewhere in this forum (alternately pressing "Heated Dry" and "Normal"; pressing any three buttons in sequence three times; and pressing and holding various buttons for three seconds each) with no success. The trouble shooting guide from Whirlpool does not address anything associated with flashing lights. I've left the door open and unlatched for 12 hours now with no change. Any suggestions that don't involve calling a repairman?
Score 7
14 Comments
What everyone fails to tell you in these answers is....1. You can't reset it if the lights are on. Each time you hit the normal and heated dry, and it doesn't work, you're sending a signal to the control board to make another selection. Wait until all the lights are off, with the door open, press the "Normal" button, then "Heated Dry, and then do it again. Shut the door and all the lights will come on at once. It's reset then. Don't try and reset it with the "Pots and Pans" light on, just leave the door open and wait for the lights to go off. This means the control board has finished running through all the buttons that were pushed and it's waiting for a new signal.
by Share
Well after replacing parts and doing the reset of normal / heat dry thing now my dishwasher lights come on but the start and resume light flashes what could be problem and how to fix please anyone
by Share
Kay Joiner- Thank you!! Your answer was perfect- the tool I needed most was PATIENCE. I had tried the Heated Dry/Normal combo so many times
by Share
I have tried everything to reset the washer. took the board and unplugged it from the inside . nothing...still flashin lights "normal and cancel" HELP
by Share
What if it's the heated dry button itself that's flashing? I've tried everything. Even replaced the control board
by Share
Show 9 more comments
Add a comment
Chosen Solution
meadbrewer try to reset your dishwasher. To reset it, you will have to have the door open. It can not be latched. Press "Heated Dry," "Normal," "Heated Dry," "Normal" within three seconds of the first pressed button. Now close the door, this should reset your dishwasher. Hope this helps, good luck
Score 14
24 Comments:
Tried that. Also tried clicking the circuit breaker off for a few minutes. Neither worked.
by Share
Ever figure out what was wrong? Mine is doing the same thing.
by Share
Is a here a resolution to blinking normal light yet? We've tried resets, stopping power for at least 1 minute. Any sure-fire answers? Thanks to all!
by Share
The reset made absolutely no change in mine.
I tried holding down the "normal" button while the door was open and, once released, it allowed me to start it up again.
But it will only get through the washing cycle. At some point during or after the washing cycle, but before the drying it stops and starts flashing under "normal" again.
Is it dead? Is it trying to tell me something is wrong with a component in the dry cycle?
Please help!
by Share
You've absolutely got to wait until the Pots & Pans/Normal lights go off and this will only happen with the door closed. Lights off, open the door, press normal/heated dry/normal/heated dry. Shut door, all lights will blink and then it's back to normal. If not, and you keep pressing buttons, it's going to take that much longer to reset.
by Share
Show 19 more comments
Add a comment
Turn off the power. Open the dishwasher, take out the top 6 screws. The top control panel should pull away from the dishwasher. Pop off the plastic cover inside to expose the circuit board. Disconnect the 14 or 16 pin ribbon cable. Turn the power on. With the power on, carefully reconnect the ribbon cable. Reassemble your dishwasher. This worked for me!
Score 12
19 Comments:
This Fix Resolved My Problem, but in the meantime I ordered the;
Dishwasher control panel
Part #WPW10175239
This part replaces W10164388.
I’m not sure what caused the error, I’ve tried resetting several times.
I always waited till all lights go off. With the door closed, lights off, I opened the door, pressed normal/heated dry/normal/heated dry & shut door. All lights blinked, then Drain/Cancel light illuminated and began draining. When I attempted to start the same crazy blinking began.
Again, as final resolve:
• I turned the breaker off
• Opened up dishwasher door and
disassembled to gain access to
control panel
• Disconnected the 14 or 16 pin
ribbon cable
• Turned the power on
• With the power on, reconnected
the ribbon cable
• Reassembled and tested normal
wash 3x, all good
I haven’t gone through all the other settings yet, but I will, seems to indicate possibly a control panel issue, but I can now wash my dishes.
by Share
I just finished doing this to my dishwasher and it is currently running (finally)! It seems to have fixed it, at least for now! Thank you so much!!!
by Share
Have a Whirlpool dishwasher. First cycle light would go on/off. Was able to do some of the troubleshooting, now normal cycle light stays on, none of other cycles work. Also no other lights functioning on options and will not turn on. Have any suggestions?
by Share
This worked. The disconnected pin cable route. Thanks!
by Share
Thanks a bunch, i followed your advice after all else failed and it worked like a charm. My dishwasher is running as we speak.
by Share
Show 14 more comments
Add a comment
I am re-posting what I found from Jason @squeeby, that works.
I’ve got WHIRLPOOL ''Gold Quiet Partner IV MN:  GU2475XTVB0
His Fix Resolved My Problem, but in the meantime I ordered the;
Dishwasher control panel PN:WPW10175239. This part replaces PN:W10164388.
  • I opened the door
  • pressed normal/heated dry/normal/heated dry & shut door
  • All lights blinked, but did not go into the diagnostic, it then illuminated Drain/Cancel light and began draining
  • When I attempted to start, the same crazy blinking began.
As Final Resolve:
  • Opened up dishwasher door and disassembled to gain access to control panel
  • Disconnected the 14 or 16 pin ribbon cable
  • Turned the power on (Breaker)
  • With the power on, reconnected the ribbon cable
  • Reassembled and tested normal wash 3x, all good
I haven’t gone through all the other settings yet, but I will, seems to indicate possibly a control panel issue, but I can now wash my dishes. So Far, So Good!
Houses the buttons and display for controlling dishwasher functions. Image
Product
Whirlpool Dishwasher Control Panel - WPW10175239
$176.99
Score 5
4 Comments:
disconnecting and reconnecting the ribbon cable reset the flashing "normal" light and it now runs fine...saved me a #150 repair bill.
by Share
THIS. Tried the button reset but it did not work.
I had the normal button blinking. The drain button was the only button that worked (eventually started blinking with the normal button as well).
I disassembled per instruction, and removed the 14 pin cable (15 pins but the harness uses only 14?).
Switched on the power, installed the ribbon cable (careful).
The dishwaser has reset and is now functioning normally.
by Share
Reseating the ribbon cable didn't work at first but with me being lazy to hit the breaker, I disconnected the ribbon cable and examined it further with the power still on and while examining the cable and harness end I moved it around "massaging"/bending the end back and forth then plugged it back in and it seems to be well now. Is it broken solder or corrosion building up?
by Share
Is it safe to reconnect the ribbon with the breaker flipped on?
by Share
Add a comment
I am so grateful for this ifixit chain on fixing dishwasher flashing lights!!! I fixed something for the first time in my life, thanks to all your posts. It seemed not to work, but thanks to Sally King, I just kept repeating. For me the sequence was: With my left hand extended to the max, hit red circuit breaker tab on the wall, which shut panel lights for about one second; instantly hit the Heated Dry button with my maximally extended right hand already hovered in place; quickly hit Normal button, then Heated Dry again and Normal again; close door. The Normal button still blinked; so I opened the door and repeated the circuit breaker-Heated Dry-Normal-Heated Dry-Normal-close door operation quite a few times. Eventually I got a full light panel display; but the Normal button immediately resumed blinking. So back to the routine, with a bit of hope. Then I got a Resume Wash, which I hit. The washer went to work; but defaulted to blinking Normal in half a minute. This happened several times. And I went back to the circuit breaker-Heated Dry-Normal-Heated Dry-Normal-close door routine. The dishwasher started up in different cycles several times, again defaulting to the blinking Normal. But it finally caught in a cycle and completed the cycle. I then ran a full cycle wash with no problems. Hallelujah!! We don’t have to call a repairman or buy a new dishwasher, thanks to y’all.
Score 2
1 Comment:
I went trough the same troubles and nothing was helping. Eventually, like for the bestresumps, the problem was solved. I gave a little thought to the reasons why the process was that chaotic and came to the following conclusions:
In the instructions, the reset steps were not quite clear. Specifically, it is not quite clear if you have to press Normal while still holding Heated dry. I think that I did that but I did that by accident trying to run the reset procedure within 3 secs , a recommendation I saw somewhere in all the responses. So, I would try both cases - to fit reset sequence in 3 secs and, if it doesn't help, doing pressing Normal while Heated dry is still pressed.
by Share
Add a comment
I also tried all of the previous reset solutions, circuit breaker trick, door opened/door closed and nothing really worked. I found another solution on another forum from a dishwasher repairman who said it is likely the touch control panel that needs to be replaced. My dishwasher is almost 15 years old so I replaced the touch control panel and that fixed my problem. It can also be the control board that the control panel plugs into as well. If you’ve tried all of the other solutions, and made sure your dishwasher is not in-between cycles, try replacing your touch panel, then the control board. It’s more like the touch panel as that gets a lot of wear and tear. The control board is 100% solid state so it’s less likely to be the problem, unless you get frequent power surges in your electrical lines. But that would do more damage than a blinking Normal light - just say’n ….
Score 1
3 Comments:
There doesn’t appear to be any electronics in the touch panel, so how did that fix a blinking light issue? Are there electronics in there? My dishwasher DOES work, but the lights are crazy, like the drying light is on when dishwasher just started filling and washing, or all 3 delay buttons are lit. I can’t turn off the heated dry button, and I can’t do a delay wash. I do have a new control panel in hand. Just wasn’t sure that would fix it. And once I install it, if it doesn’t work, I can’t return it. Any advice?
by Share
Pots n pans flashing , normal flashing... before that 4 hour delay was flashing, have door closed and awaiting flashing to stop to start reset process. What a pain . Any updates advice greatly appreciated
by Share
You're right there are no electronics in the touch control. It is a bubble control in that when you push a "button" you are closing the gap between the front of the panel to touch the back of the panel which closed the circuit and sends a signal to the main board. That is why the control panel is usually the problem. The "bubble" collapse which makes the front touch the back which then sends a confusing signal to the main board. Hope this helped.
by Share
Add a comment
My start/resume light kept flashing and after doing the reset sequence about 5 times, unplugging in between, then cancel/resume button. Normal and heated dry buttons pressed it would start flashing again. After opening/closing. Cancel. Normal. Cancel. Normal. Cancel. Opening in between each time it finally started working. Thank you!!
Score 1
Add a comment
Just wanted to add the cause of our problem on our Whirlpool QP3 in case it can help another consumer. After dismantling our dishwasher door and control panel, I found and eradicated several German cockroaches. I assume these roaches were sheltering in the control panel for warmth and they were also relieving themselves on the main PCB. Our house is located in the woods in GA and, despite regular pest treatments and a clean home, roaches in GA are just a reality.
I killed the roaches in the panel, removed the dishwasher completely from the kitchen counter, and sprayed insecticide both around the machine and inside the dishwasher door that, once dry, continues to provide protection against pests. Once I cleaned all of the fecal matter off the PCB, let it dry THOROUGHLY, and reassembled the machine in place, the dishwasher is functioning flawlessly once again. Just in case others could be experiencing the same problem, I wanted to add our fix.
Score 1
Add a comment
What finally worked for me was that I pressed the suggested button sequence immediately after I plugged the power back on. I repeated the sequence several times while the dishwasher was plugged in, and it just wouldn’t work.
Try disconnecting power, and within a second of powering the dishwasher follow the reset sequence the others have described. Good luck!
1 Comment:
This worked for me, thank you so much!
by Share
Add a comment
I have a quiet I partner dishwasher the clean light flashes 7 times pauses an repeats 7 times please help me it’s not worked I. Almost a month I got a heating element coming tomorrow and I’m hoeing that will fix my problem but does anyone else have any suggestions on what I can do!!
1 Comment:
I have the same problem exactly
by Share
Add a comment
I dont have a normal
Add a comment
If you can’t get the lights too go off can this start a fire
Add a comment
I also got my Quiet Partner IV fixed by unplugging all low-voltage connectors from the PCB (i.e the flat-flex ribbon as well as the white connectors on the edge of the PCB, the ones with the colored wires) and treating them to a good clean as well as spraying all contact surfaces with De-Oxit.
When unplugging those colored wires from the PCB, pull them away from the PCB in the same plane as the circuit board, do NOT pull UP on the wires: The wires go into the connector at a 90-degree angle. So if you imagine the PCB laying flat on the table with the colored wires on the far side, then pull the connector AWAY from you, NOT up. I had quite a bit of corrosion on those edge connectors, so I cleaned them using a rough paper towel and Isopropyl alcohol, ON BOTH SIDES of the PCB. Similarly for the connectors, you can run an IPA-soaked paper towel sideways through the connector because the connector is "open" on the sides.
I also unplugged the other end of the narrower of the flex-flat ribbons, it goes to the digit-display module.
After that, I sprayed De-Oxit on all of the connectors and PCB contact surfaces.
For re-assembly, don't worry about remembering which of the colored wires goes where, the correct colors are written on the circuit board, just follow that.
Add a comment
I own the Whirlpool Quiet Partner II. I was able to resolve my issue after some trial and error. Basically my normal light was blinking. Then if I hit cancel, the normal and cancel light would blink. I could not get it to reset after trying every method mentioned here and watching every youtube video. I replaced the control board with a used part from ebay and it worked for a cycle or two, then back to the same thing. BUT this time I noticed it was overflowing into the sink. So my error was not the control board, but a drainage issue. I disconnected the hose that drains into my garbage disposal and cleaned it out with a long bottle brush and I cleaned the opening going into my garbage disposal. Ewww there was lots of stinky black gunk clogging it up. Still though my dishwasher would not reset at all. Even after turning off the circuit breaker and doing the "heated dry normal" thing several different ways. Finally I accessed the control board again with the power turned off at the breaker. I disconnected every wire harness on the board (5 total). I also took a toothbrush and some kitchen cleaner to the door switch than engages when you close the door. I was kinda gunky so I made sure the switch popped in and out freely by pushing on it with a flathead screwdriver. Probably wasn't the issue, but why not while I'm in there. Next I reconnected the wire harnesses, put it all back together and flipped my circuit breaker back on. The dishwasher went into cancel mode and drained. Then after that the lights were all off and it worked normally again. YAY.
Now I know that poor drainage can trigger an error that is not easily reset. I wasted $40 buck to replace the control board which was not even the issue. But I learned a thing or two in the process and I am patting myself on the back!
Add a comment
Kitchen aid KUBIO2RILO Dishwasher no reset breaker or button worked. Flashing normal constant.shut Brkr off Took 6 screws out. Unplugged ribbon and plugged back in. Turn brkr on no lights. Hit rinse light went out reset brkr and hit rinse hit resume. Started up. I had stopped it before cycle complete this is why no error codes. Thank you all for answers.
Add a comment
Add your answer
meadbrewer will be eternally grateful.
Past 24 Hours: 15
Past 7 Days: 122
Past 30 Days: 488
All Time: 143,266
