Updated Apple TV with second generation A5 processor / Released March 7, 2012
Warning message Apple TV overheating
Hi
My Apple TV 3rd gen had started displaying message:
'warning' 'apple tv is overheating and will shut down , this message will disappear when apple tv is ready' or something very similar. The unit is in a well ventilated area and has never been abused, and is less then 3 years old. Ive updated the software( it barely let me do that before failing) and ive tried resets etc. but it isn't possible to even turn the unit off now , only by unplugging the power lead.
Any help tips or advice would be most appreciated
Regards
Mark
York UK
Score 1
2 Comments:
How old is it?
by
Image pleasr
by
Add a comment
Did you try using some can'ed air to blow the dust out from the inside yet?
Also make sure you give it some breathing room, you don't want to cook in a closed cabinet with other hot gear.
Add a comment
It is most likely the on board temp sensor. The only thing I can think of would be to disassemble everything right down to the board and do a solder re flow, by either using a heat gun to bring the board up to temperature so all the solder points re connect or you can also do this in an oven. This method is for repairing cold solder joints on the board, which could be the cause if the machine heated up enough to melt the solder and cause it to loose its contact. Try Google and search for "Solder Reflow"
Add a comment
Add your answer
Mark Hansell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 2,958
