A one-hand dispensing 12-Cup programmable coffeemaker with an insulated tank and heater that was released on December 15, 2008 and produced by Hamilton Beach.
Why does my coffee taste bad?
My coffee usually tastes good. Recently though, my coffee has tasted worse and the coffee grounds are kind of gritty in the coffee. What should I do to correct this?
1 Comment
Have you changed anything? Where do you get your water?
by
Add a comment
Most Helpful Answer
If your coffee is tasting bad, it could be a result of poor water quality, incorrect coffee to water ratio, the coffee grounds are either too fine or too coarse, or the coffee maker might be dirty. Solutions to these issues can be found in the Hamilton Beach 48464 Troubleshooting page.
Score 1
Add a comment
There are some another serious reason for your coffee is tasted bad. If you don’t clean your coffee machine regularly then your machine make a bad effect to your coffee flavor. The coffee flavor with smell and drinking bad. So you must need to clean your machine every 2 days of 3 days.
Or if your coffee bean is grinned with high speed then it can create a bad flavor taste.
Score 1
Add a comment
You can let straight vinegar sit in the tank overnight. Believe it or not, it might fix a whole lot of taste issues.
Score 1
Add a comment
Add your answer
Michael Damico will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,860
