4.5 Cu. Ft. Compact Refrigerator
Fridge Restartiing problem repeatedly
Fridge working for some hours normally and suddenly stopped for 5 to 6 hours and then automatically work for some hours its repeating, i already checked capacitor and thermostat and compressor they r ok, plz solve my problem
Add a comment
Chosen Solution
Cause 1
Condenser Coils are Dirty
The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won’t dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty—if the condenser coils are dirty, clean them.
Cause 2
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Cause 3
Condenser Fan Motor
The condenser fan motor draws air though the condenser coils and over the compressor. If the condenser fan motor is not working properly, the refrigerator won’t cool properly. To determine if the fan motor is defective, first check the fan blade for obstructions. Next, try turning the fan motor blade by hand. If the blade does not spin freely, replace the condenser fan motor. If no obstructions are present and the fan blade spins freely, use a multimeter to test the fan motor for continuity. If the condenser fan motor does not have continuity, replace it.
Score 3
2 Comments:
Thank you soo much! Just saved $75 on parts and labor.
by
Ivan, glas I could help. You must get cheap service calls in your neck of the woods.
by
Add a comment
Hey, that definitely sounds frustrating! Since you’ve already checked the capacitor, thermostat, and compressor, one possible culprit could be the starter relay or overload protector — these can intermittently fail and cause the fridge to stop and start like that.
Another thing worth checking is dirty condenser coils — if they’re covered in dust, the fridge can overheat and shut down temporarily. Also, make sure the fridge has good ventilation and isn’t pushed up too close to the wall.
Add a comment
Add your answer
vasuyellapu1981 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 26
All Time: 2,249
