13.3" ASUS i5-4200u HD Tablet
keyboard problem with Asus Transformer book
Hi guys! i have a problem with my asus keyboard, only works function keys and i can modify the brightness and volume so i decide to restore my pc with the option with restore the pc and install the SO that comes with the pc originally, but in the process
needs to press F12 and now my pc its totally blocked, y try to turn off but nothing happens and when i turn on appears the same screen that needs to F12 be pressed so i can't do anything . I try to connect a keyboard by USB but doesn't works.
This is the image
Thanks so much!
Add a comment
1 Answer
Hello ! I just poped in by chance , should I say , because I try to solve a batterie problem on my Asus T300LA of 2,5 years old. In fact the charging device doesn't get the signal to start the reload process when the batterie reaches a certain low level of charge - maybe around 90% of her capacity.
And maybe to solve your problem , you should try the procedure I found on the web whiich is supposed to help in the case of the battery charging problem ! ? ! What to try ?
Or - 1 ) Just unplug the battery connection + unplug the charger connection + keep pushing on the " start " button during 10 ~30 secondes + reconnect the battery + reconnect the charger (unless the battery is +/- charged.
Then start the PC again and see what happens. Anyway this is the procedure to follow when you get a battery problem. But maybe it works also in your case .
Or -2) Here is what you could do or try before following the n°1 hint.
It would be kind of you to come and tell us if it helped or not and what you finally did to succeed your repair and even if only partially solved your Asus pc problem. Thhs in advance . Tchotto on the Web: nothing to sell.
Mise à jour (17/08/2016)
Hello again ! Correction of my previous answer . Because of maybe some precipitation trying to help you, eventhough your post is already 5 months old !! I forgot to add the second hint, sorry .
Here it is : hint 2 : simply keep pushing the start button for +/- 20 s and then try to start again you PC as usual . Good luck ! Thanks in advance to all of the readers who will let us know if it helped, or what solution they found successfully , the parts they changed or soft they manipulated or the cost of the repair. Ciao !
Tchotto on the Web: nothing to sell .
Add a comment
Add your answer
Sergio moral will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 23
All Time: 2,192
