Sony’s 20.1 megapixel camera designed to capture still images and video recording. Model number: DSC-W800.
Why will my device not power on?
Why won't my Sony Cyber-shot DSC-W800 power on? When pressing the power button nothing displays on the screen and the device seems to be unresponsive.
Could this be a battery issue or something more serious that would require repair?
Score 1
2 Comments
يرجى توضيح أكثر هذا قليلا
by
@tcampo what happens when you do replace the batteries? does it then turn on?
by
Add a comment
1 Answer
Chosen Solution
There may be several reasons why your device may not be powering on. Following are the common ones:
  • The battery may not be sufficiently charged. It may discharge automatically if not used over a long period of time. In this case, simply charge the battery. Also, check to make that the battery is inserted in correct orientation.
  • The battery terminal may not be clean. You may clean the terminal with microfiber.
  • External temperature also effects the way the camera functions. Thus, make sure to not use the camera when the temperature is above or below 0-40° C. Condensation might occur if the camera is moved from extremely cold temperature to a warm environment, which could prevent the camera from functioning properly. In that case, let it come to room temperature and allow the condensation to evaporate naturally.
  • For more information, refer to the troubleshooting page.
Score 3
Add a comment
Add your answer
Thomas Campo will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 26
All Time: 1,919
