The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
Vibrator motor not working
So I replaced the screen on my Xperia Z3, then I re-installed everyhting, and everything works except the vibrator motor, I thought maybe I broke the motor so I bought a replacement power button assembly (that has the mic and motor) I replaced it, but it still doesn't work. I didn't replace that tiny little piece that it connects to, because frankly I can't find it for sale anywhere. Do you think that is it?
Any solution?
1 Comment:
Hi Max
Usually the vibrating motor is on the cable with on/off and volume buttons. If you replace that cable and the motor doesn't work maybe the cable is faulty.
Hope you fix it soon.
by
Add a comment
The vibrator motor is connected to the ribbon cable, Next to the motor there is a connector that gets plunged inn. There is a pink rubber insert that covers the motor that helps with vibration and noise. The motor will still work without the pink rubber insert.
That cable is very fragile, most likly it was damaged during installation.
Add a comment
maybe your screw very tight, loose a bit.
Add a comment
I exactly have a same problem.
I replaced my lcd, then the vibrator & mic doesn't work.. so I replaced the main flexible. The mic is working but the vibrator just stand still.
Still have no idea,
Is there any possibility it caused by the software error or something ?
Add a comment
Add your answer
Max M will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 3,139
