Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
No backlight screen is dark
My iMac is A1418 2013 MF883 LM215WF3 (SD)(D1) 21.5".
I installed new screen display and have same issue
I shine a flashlight at an angle at the display and see the faint image of the desktop and icons. How do I fix the backlight?
Which is it? The CFL's or the power inverter on the iMac 21.5" 2013 model.
Thanks
Score 3
Add a comment
1 Answer
Most Helpful Answer
This model uses LED's for the backlight and the power is supplied via a ribbon cable from the logic board.
Review this IFIXIT guide: iMac Intel 21.5" EMC 2805 Display Replacement. Jump to Step 20. Make sure the cable is correctly inserted.
Use a magnifier to inspect the pins of the cable and the socket as they could be damaged. If they look OK, you'll need to do a detailed inspection of the logic board as something has likely blown.
Score 2
Add a comment
Add your answer
Thuan Tran will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 1,478
