The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
Screen is not as bright
I had to replace my complete screen ( touch digitizer and LCD screen).I. put it back together and it came on but noticed screen was not as bright even though brightness controlled all the way up.If I put it on auto bright you can barely seen the screen. I doubled check the LCD ribbon and seem to be in good. Any ideas on what could be the problem.
Score 2
Add a comment
Chosen Solution
Not sure who you got your screen from but sometimes there's a protective film on the screen that's tinted you need to peel off. Ive made that mistake once myself.
Score 1
3 Comments:
No I removed that
by
My screeen became dim after I upgraded to 10.1
by
@rouadi1 In your case I would check my settings in power settings and in the display settings. Sometimes upgrades change default settings
by
Add a comment
Its your front camera flex cable (there is proxy on it) and this proxy didnt recognize light propertly
Score 1
Add a comment
Add your answer
Arletta will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 16
All Time: 1,709
