Scanner ADF not working including light
Not able to use my ADF scanner. Does not feed nor does the light come on indicating anything in feeder. Wondering if the sensor is the issue, but not able to find. I do not have a jam, or paper stuck. Very clean. Any help would be grateful.
8 Comments
Hi
Does scanning work when you use the PC Epson Scan software, from the printer control or neither? Does the scan option work using the platen glass?
by jayeff Share
Hi! Yes my scanner works from flatbed but not auto feed.
by Kath Share
I have the same issue. Also, the Epson Scan software does not recognize the printer connected at all. So that solution can not be tested. Flatbed scanning with the device control panel worked fine and automatically discovered the PC's in the house. ADF is what is totally dead.
by specialsmith Share
Flatbed scanning with the software worked fine and automatically discovered the Mac in the house. ADF i scanner dead is what is totally dead. It sees my PC will not scan using scan controls on printer or software on computer.
by Albertice Share
I have had no trouble printing but when I try to use the ADF to copy multiple documents, it tells me to place the documents on the glass, what good is the ADF? My instructions read as if I can use it.
by lfm1201 Share
Show 3 more comments
