Anyway to replace sd card slot
a falty sd card riped pins out of my wii u is there any way i can replace it and where can i find the parts if i can replace it
E-bay/amazon for the sd slot...but would be to hard to unsolder/solder for most people.
Maybe a phoneshop that does repair could help you out?
Or call nintendo see if they can help... But user damage costs a lot :(
Did it completely rip the pins out because i forced my sd card out and some of the pins bent down. I used a flashlight and a tiny screwdriver to bend the pins up for my wii u. You should check inside the sd slot to see if you have any bent ones, you should have at least 9 pins in the sd slot. If your pins got ripped out you have to solder a new sd slot in your wii u.
Here you can find the card slot replacement part:
Let me know if you need any more help.
I almost have the same problem, but so far i’m in hope for a solution, i know there’s something and someone out there who can fix my Wii U’s SD Slot
Im aware this is an old post, but I also had a broken wii u sd card reader and wanted to replace it, and after looking far and wide for the exact component, I was able to find the exact part from JLCPC. The MFR Part # is "SCDABA0800" and it's from the manufacturer "ALPSALPINE". Here is the link https://jlcpcb.com/partdetail/ALPSALPINE.... Hope this helps someone at some point!
Actually if you want to purachse the part directly you would have to do it on lcsc: https://www.lcsc.com/product-detail/C370...
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 3,085
