How to replace the front LCD panel?
I need help on the substitution of the front panel (cracked) of my Zuk Z1 by Lenovo.Have you got any suggests for the disassembly?Thank you.
Hi,
Here is a link which shows how to dis-assemble a ZUK Z1.
Hopefully it is of some help to you.
Link broken. Please update!
@c0fynian0 here is the Zuk Z1 disassembly
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 22
All Time: 7,983
5 Comments
I have the same problem.
by falesat
where did you order the new screen?
by marinathijssens
I do have the same problem, could you help where to order for the new screen?
by thilakraj14
Alibaba or part4repair
by nehvizuli
Hi, you can find the disassembly process on youtube. You need to remove back cover, sim slot, battery, antenna cover, upper mother board, lower circuitry and be careful with connectors and cables. The display is quite tricky since you need to heat up from the front detach it from the frame and use some double side adhesive to glue the new one to the frame. You can find replacement displays on ebay.
Hope this helps
by alessandroleona
