An economy SUV by Mazda, not the greatest sport utility vehicle in the world, just a Tribute. Made in the USA by Ford Motor Company. Simply a rebadged Ford Escape.
Where is temperature sensor located?
Where can I find the temperature sensor on my 2003 Mazda Tribute 4 cylinder engine
Score 4
4 Comments
Where is the heat sensor located on Mazda tribute 2003-2007?
by
where is the location of thermostat switch sensor of mazda tribute 2001 and to remove
by
Where is the heat sensor located?
by
Any video available?
by
Add a comment
Most Helpful Answer
@chasp you did not tell us exactly what temperature sensor you are looking for. It might also help if you tell us why. The 2003 Mazda Tribute with the 2.0L 4-cylinder does not use a traditional Engine Coolant Temperature (ECT) sensor that sits submerged in antifreeze. It uses a Cylinder Head Temperature (CHT) sensor that measures the temperature of the metal itself, and the computer uses that reading to calculate the coolant temperature.
Score 3
1 Comment:
Yes it's the coolant temperature sensor
by
Add a comment
under the intake manifold on the back of the alternator, better to remove the alternator so u can see the coolant temprature sensor.✌
Add a comment
Add your answer
Chas Plunkett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 50
All Time: 9,940
