The Game Boy released on April 21, 1989 in Japan, followed by North America on July 31, 1989, and lastly in Europe on September 28, 1990. It is characterized by a large grey casing and model number DMG-01.
My start button or a button wont work
When i loaded tetris i got the nintendo ding and it started but when i tryed to start the game it wouldn't i don't know if my game is broken or my gameboy.
Score 5
3 Comments
where can i send my gameboy for repair?
by
i will pay for the repair.
by
MY EMAIL ADDRESS IS: butchnthelma@gmail.com
by
Add a comment
Most Helpful Answer
Hello Nick, sorry about the horribly late response, you know how these sites are, sometimes you get a response within a day, sometimes in over 8 years...
For this I am assuming you have an original GBA or older, if this Gameboy is an SP or newer, I cant help you.
This is a relatively easy fix, the most common reason for this problem is that the conductive pads under the silicon pieces have become coated with... stuff? (I have no idea what the heck it is.)
> Take out the six screws on the back, two are under the batteries. They are usually tri-wing, but I have seen Original Gameboys have Phillips.
> The ribbon cable connects the two halves together. Be very cautious as if you tear this ribbon cable in any way, then congrats, you broke your screen. To remove on an original Gameboy ribbon cable, get a good grip on it and pull it out of its housing. If this is a Gameboy Pocket or newer, lift off the back shell. You will see the workings of the Gameboy. push up the two tabs on the sides of the ribbon cable, take out the three Philips screws, disconnect the ribbon cable and lift up the board.
> (Only follow this step if you have an original Gameboy) Take out the TEN (bit of an overkill there really...) Philips screws on the screen half of the board, and lift off the board. The screen is attached to this board, so be careful.
> Last step! remove the silicon piece of the button that is giving you trouble, and grab a piece of paper. Push the silicon piece and you should see the conductive pad stuck to the inside, take it and rub it on the paper, you should see a pencil-like mark appear on the paper. This cleans the pad. You can now reassemble the Gameboy and test it out.
My god that took ages to type...
Score 5
2 Comments:
oh my lord thank you for this! my original GBC had issues with its start button for about a decade now and this finally fixed it! did have to get some special tools to get the triwing bits but i had no idea what the actual issue would be.
by
Worked perfectly, you're a childhood saver!
by
Add a comment
Open it and check the point, where the Start-button press on the logic-board.
Maybe try another game, if the start-button works on another game, the Cardridge is damaged.
Score 3
Add a comment
A ver si os sirve este vĂ­deo
https://youtu.be/G9P1tYU3muM
Add a comment
My start button does not work
Add a comment
Add your answer
Nicolas Leonardo will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 42
All Time: 18,572
